Old 04-26-2017, 07:41 AM
Try2paz's Avatar
Try2paz Try2paz is offline
Default 1966 Mustang FastBack for sale "Track Ready"
Item Location (City/State): Livermore, CA
Price: 55k
Description: 1966 Fastback
https://mikemaierinc.com/2017/01/nat...mustang-gt350/
351 windsor (Blown Head Gasket or Needs a new set of rings) Either I sell it now or put a motor back in it and sell it more more later.
Motor made 350RWHP at 5500 RPM. Pro System Carb, Full MSD, AccuSump, Sea Tab Oil Cooler. I had a fuel pickup issue last week and car went full lean. Car runs but has coolant in oil.
4 speed toploader transmission / Mark Williams Drive Shaft "Chromoly" with 1350 Yokes
9” rear end with detroit locker
C&R radiator
Fuel Safe 20Gal Cell
MMI quick ratio power steering system with KRC pump
MMI Front MOD 1 coil over system with single adjustable JRi shocks (500 / 650 spring setups)
MOD 1 lower control arm assembly
MMI MOD 1 rear suspension kit
MMI 200 lb leaf springs
Bilstein shocks
MMI panhard rod system
MMI 1/2″ sway bar
Custom fitted interior
Woodward steering column
Momo suede steering wheel
Sparco seats / 6 pt Schroth Belts
Rear seat delete
Racepak IQ3 dash/data logger
Wilwood brake system
6 piston Superlite6 front brake kit with Thermlock pistons & 12.88″ rotors
4 piston Superlite4 rear brake kit with Thermlock pistons & 12.88″ rotors
1″ master cylinder
Stainless steel brake lines
Budnik 18×8 wheels wrapped in 225/45/18 tires
Complete Re-wire of entire car with coach works.
This car was built over the past two years and I've got receipts for everything I've got over 100k into the build not including the motor.
MMI, Inc put the car together and knows everything about it outside of the motor.
I ran last weekend at Thunderhill and was passing new Z06's in this beast. I hate to see it go but with the motor letting go and having my second kid life's priorities have changed.
1967 Nova
2018 Camaro ZL1 1LE
Old 04-26-2017, 04:37 PM
DanielBurko DanielBurko is offline
What motor is in the car? Crate? Built by? Thanks
Old 04-26-2017, 05:09 PM
Try2paz's Avatar
Motor 351w, built in LA, older trick flow heads 188cc, edelbrock intake, pro systems carb, aviad road race pan, accusump, Seatab oil cooler, full msd
1967 Nova
2018 Camaro ZL1 1LE
Old 04-26-2017, 05:12 PM
Any engine bay pics? Is the data acquisition system still in it with the race pack?
I looked on Mike's site and did not see any engine pics or a clear interior pic? Or the backseat removed ?
Old 04-26-2017, 08:44 PM
Try2paz's Avatar
I grabbed a couple quick pictures tonight in the garage. I'll get the car out in the Sun this weekend and take some pictures.
I've got a very nice PS setup, It's KRC Pump, Nascar Remote Canister with internal baffling, and a inline lower radiator hose cooler. I've got close to 4k In the PS setup.
C&R Radiator (Dual Fans)
I had this "Control area" put together so you could still operate the car belted in. It's got Fire Pull, ignition, start, and turn signals and horn
All the carpet is brand news, door panels are band new as well
1967 Nova
2018 Camaro ZL1 1LE
Old 04-26-2017, 08:48 PM
Try2paz's Avatar
Yes the data acquisition setup is part of the IQ3 Logger which is in the car. I've got V-band setup on Oil temp, Oil pressure, Volt, Fuel level, Water Temp, A/F, and GPS Speed. Its a sweet setup you can overlay racetracks on the computer and figure out how much G's your pulling in certain corners enter / exit speeds the possibilities are endless with it.
https://store.racepak.com/collection...nt=25963755587
1967 Nova
2018 Camaro ZL1 1LE
Old 04-27-2017, 07:46 AM
Mathi Mathi is offline
If I had the money, this would be my next one! Good sale!
Old 04-27-2017, 12:56 PM
Build-It-Break-it's Avatar
In the Maier link it says it's a 65 but listed here as a 66? My wife and I are interested in the car. Thanks
Ahmad B
Old 04-27-2017, 01:28 PM
Try2paz's Avatar
It's a 66, I recently looked at the Vin tag and it's an original A code, 4 speed car with Emberglo exterior and Emberglo Deluxe Interior package.. rare ish color combo.
I've got a few people interested so PM me for more details / setup time to view.
1967 Nova
2018 Camaro ZL1 1LE
Old 04-27-2017, 02:47 PM
Flash68's Avatar
Flash68 Flash68 is offline
Sweet car!
Any local track lap times to reference?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
