Old 05-04-2017, 07:14 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Default Ridetech StreetGrip for G Body!
The G Body StreetGrip has made it's debut and is ready to ship! Just like our other Streetgrip packages, this one includes some similar components. Here's what's included:
  • Dual rate coil springs for the front and rear
  • HQ series smooth body shocks
  • Front & rear sway bars
  • Delrin bushings for front upper & lower control arms
  • Tall upper balljoints
  • 2" drop spindles
https://lateral-g.net/forums/atta...1&d=1493906973
Here are some ride height dimensions and pictures. I just installed one of these kits on an Olds 442, the difference in the way the car drove and handled was incredible.
Old 05-12-2017, 02:14 PM
TheWraith's Avatar
TheWraith TheWraith is offline
Very interesting! Do the spindles have any corrected geometry?
Old 05-23-2017, 08:17 AM
I just now saw your response, sorry about that! The spindles are a standard 2" drop spindle. We used them on this particular kit so we could utilize a dual rate coil spring. If the spindles weren't used, we couldn't get a dual rate spring in the length needed.
However, we do use a .5" taller upper balljoint to add more negative camber into the curve.
