Old 05-07-2017, 06:32 PM
Timberline's Avatar
Timberline Timberline is offline
Default Clutch set up
Just curious what kind of clutch set up everyone is using.
Dual disk, single disc, steel flywheel, aluminum flywheel?
525 & up horsepower
Jeff
66 Nova Sport Coupe
Detroit Speed equipped front and rear
LS3 525hp, t-56 6spd
Build in progress
Old 05-07-2017, 08:20 PM
gnx7's Avatar
gnx7 gnx7 is offline
A McLeod RST twin disc will have the pedal pressure of a Honda Civic and not grabby rated at 800hp. IMO one of the best street clutches you can buy/drive. Stock slave cylinder also.... no shimming etc. Pair it with an aluminum flywheel.
If you are going to be doing abusive launches at the drag strip or on slicks/prepped tread surfaces just get the RXT for longevity.
Old 05-19-2017, 09:54 AM
Timberline's Avatar
Smile
Thanks gnx7 just the answer I was needing
Jeff
66 Nova Sport Coupe
Build in progress
Old 10-07-2017, 01:03 AM
Nativefx Nativefx is offline
I went with the McLeod RST as well. It was either that or Monster, but didn't get enough feedback on the Monster and lots of positive about the RST.
