Old 05-19-2017, 09:24 AM
Swiftshifter68 Swiftshifter68 is offline
Default Hogan's Racing Manifolds sheetmetal EFI for Gen II SBC
Item Location (City/State): Yuba City, CA 95991
Price:2000.00
Description:For your Gen II SB Chevy (LT1/LT4), Hogan's Racing Manifolds fabricated aluminum sheetmetal intake, nice shape, no damage, intake port dimension is appx. 2.25" x 1.36". Two reference ports at the rear of the plenum, includes fuel rails, w/8AN crossover, full set/8x Bosch/Delphi style 1,000cc/96lb.hr. injectors (Low Impedence).Also has the standard SB Chevy distributor location added ($100 add-on from Hogan's), but easily plugged if using the OEM Optispark, other method. Arizona Speed & Marine 58mm throttle body in nice shape, operates perfectly smooth. This manifold is $2900 from Hogans Racing, then the Bosch injectors are ~$350/set, throttle body is ~$400 new. This will breathe and feed ~1,000RWHP without much trouble, plus looks like it will clear the OEM flat hood on C4 Corvette and 4th Gen F-Body cars.
$2000, plus the ride for everything
Outlaw Performance
301 Burns Dr., #C-2
Yuba City, CA 95991(appx. 40min. NORTH of Sacramento)
(530) 751-3966
Thank you!
