Old 07-01-2017, 09:09 AM
69greyghost 69greyghost is offline
Default Ls conversion parts recommendation
Guys, I have a new Project. I have acquired a 67 convertible camaro. The car has no motor or trans and needs some work, however I am gonna ls it and was seeking some feedback on possible components I should use that are not going to break the bank. I want to get some long tube headers, a gas tank, a radiator, and a possible oil pan for an ls conversion. I would like them to be under 400 dollars each item. Thanks in advance guys.
Old 07-01-2017, 12:13 PM
im4u2nvss im4u2nvss is offline
https://www.holley.com/products/ls_p...ap_components/
These parts work well with a stock subframe. Not sure about your $400 each item.
Old 07-01-2017, 03:44 PM
Tim john--- Tim john--- is offline
I too went with the Holley LS conversion kit, engine mounts, stainless mid length headers, transmission mount, it all bolted in perfectly. I sent my original wire harness to Speartech for stand alone operation and computer re-flash, Rick's stainless fuel tank. I have a MAST oil pan which also fit perfectly. The only item under $ 400.00 was the oil pan. Application is a 69 Firebird convertible with a modern GTO engine and Tremec TKO-600 five speed.
Tim john---
Old 07-12-2017, 02:09 PM
colorado80439 colorado80439 is offline
Or you could just do this!
https://denver.craigslist.org/cto/6206504852.html
Old 07-12-2017, 02:40 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Long tube headers, radiator & fans, and an EFI tank for under $400?
I think you need to buy used parts.
But actually I have a set of Holley/Hooker LS swap headers that i'd sell you for $400, they were used for mockup.
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 07-19-2017, 07:06 PM
markos920 markos920 is offline
-Dale
Is this short or longtube? Also, will it fit 72 nova with all Holley swap parts?
Old 07-20-2017, 12:15 AM
-Dale
Long tube headers were not a requirement. Just headers in general, I got the spectra tank for under 300 bucks, and a radiator from superior radiator in Michigan. I used their radiator in my previous swap and it worked flawlessly. I paid 400 on the dot for my radiator that includes shipping. These parts are proven to me. All I need is the oil pan and I may look into the holly one. Used parts would be ok but I got some decent ones without going used. And for headers I went with the e bay shorties. This isn't a performance build it's a cruiser. I think I will be fine with the parts I selected.
