Old 07-04-2017, 01:54 PM
michics's Avatar
michics michics is offline
Default LT!/T56 Speedometer Question
My question is can a manual speedo vs a electric be connected to this style trans ? If so how ?
Thanks, Mike
Old 07-04-2017, 08:14 PM
minendrews68 minendrews68 is offline
Thanks, Mike
It can, it just takes a adapter that converts the pulses of the vss to a manual gear driven cable operated one. I had the same dilemma, but opted for the electric version of the speedo. The adapter is a little pricey.
Old 07-05-2017, 12:28 PM
samckitt's Avatar
samckitt samckitt is offline
This is one method:
http://www.abbott-tach.com/cablex.htm
When I did this swap in an 86 Monte SS, I found an OEM electronic speed that was similar in sweep to the Monte & grafted it together.
Jags That Run used to make a T56 tail housing that had a mechanical drive.
Or get an aftermarket electronic speedometer.
Scot
86 Monte SS
LS2/T56 Magnum
