Old 07-13-2017, 07:34 AM
Rob Ruthless's Avatar
Rob Ruthless Rob Ruthless is offline
Default Thermal Insulation with Sound Dampening
Membrane, by Restomod Air is the only true thermal insulation with sound dampening material. We found that custom car builders were using standard “sound dampening” material in their builds, and were unaware that it did not provide insulation from the outside elements. Membrane four-layer material that prevents your vehicle from being robbed of the climate control temperature you have set in the cabin, while giving you sound dampening.
http://www.restomodair.com/shopprodu...mal-insulator/
http://www.restomodair.com/?p=7221&p...b&preview=true
Old 07-13-2017, 07:46 AM
redfire69's Avatar
redfire69 redfire69 is offline
looks like you've got questions in a duplicate post from May: https://lateral-g.net/forums/showthread.php4?t=54977
Ron
69 Camaro Redfire
