Old 07-14-2017, 07:27 AM
paulk68 paulk68 is offline
Default t-56 magnum slip yoke
can anyone recommend a slip yoke for my t-56 magnum? i am a little confused by all the sizes and options. This will be behind a 480hp ls3. I have not ordered a drive shaft or rear end if that helps.
Old 07-14-2017, 08:19 AM
Oleyellar Oleyellar is offline
Default Ask the Vendor
I would give your driveshaft maker all the specs of the engine and length measurements, and let him recommend what hardware to put on the driveshaft. He will know the strength of the parts he sells, IF its a good shop. Most shops know this stuff inside and out.
Old 07-14-2017, 10:54 AM
assuming you are under 1K HP/TQ.. how about this option.. http://www.schwartzperformance.com/p...lip-yoke-1350/
