Old 07-23-2017, 02:19 PM
dwilson's Avatar
dwilson dwilson is offline
Default Mini tubs & Narrowed axle?
Does a mini tub kit from Detroit Speed require anything other than a narrowed tank? Wondering if a narrowed axles is also required as I have not seen this need in my research. Thanks in advance!
Old 07-23-2017, 03:23 PM
dhutton dhutton is offline
You do not need to narrow the rear end. Guys narrow it because they like the look of a fat wheel lip. You only need a narrow tank if you are running leaf springs.
Don
Old 07-23-2017, 03:27 PM
Tim john--- Tim john--- is offline
You will also need the offset shackles if your car has rear leafs. DSE makes very nice ones.
Tim john---
Old 07-23-2017, 04:33 PM
dwilson's Avatar
Don
I am having to do this little by little right now, so I assuming the only way to get away from leafs are running a 4link or watts link type of rear suspension. I'm not sure if I could just simply switch to a rear coilover with addition modifications, correct?
Old 07-23-2017, 04:34 PM
dwilson's Avatar
Tim john---
I'm checking out their 3" drop mini tub kit, they also have narrowed tanks as well which I could do in one order.
Old 07-23-2017, 04:47 PM
Pretty sure you're going to have to relocate your leaf spring perches. I think it is almost a wash to go with a Ridetech four link and be done with it....
Don
Old 07-23-2017, 05:24 PM
ADY's Avatar
ADY ADY is offline
Don
Agree, I purchased my '68 Camaro with the DSE leaf kit that came with the mini tubs, and swapping it out for the ridetech 4-left link. Tired of noise and mushy ride.
That said I'll have an awesome used DSE leaf & shocks, offset shackles, and Caltrac traction bars in a few months for sale.
-Adam
1968 Camaro SS
Old 07-24-2017, 07:02 AM
Ketzer's Avatar
Ketzer Ketzer is offline
I'm running a torque arm rear suspension on mine and really like it. Not any cheaper than the other types you listed, just a different option.
Old 07-30-2017, 08:23 AM
dwilson's Avatar
Don
If I'm n for the mini tub already, how can I get into a 4link for less than $1g? Then I'm throwing away the leaf spring suspension parts I had to buy already? Is there a kit w/o the leafs?
Old 07-30-2017, 08:30 AM
Ridetech 4 link is not much more than $1k. If you can't swing that I think you are in for a rude awakening on your build....
Don
