Old 08-01-2017, 02:30 PM
DT69Cam DT69Cam is offline
Default LS3 Crate Engine oil pan sensor
OK guys, what did you do with the sensor on the original LS3 oil pan ??? Low Oil level sensor maybe ?? The NEW Holley pan 302-2 does not have a provision for it.
69 Camaro Convertible (LS3/TKO in the works)
Old 08-01-2017, 09:12 PM
randy randy is offline
Why do you need it?
Old 08-02-2017, 04:44 AM
TomM's Avatar
TomM TomM is offline
It's a low oil level sensor, typically connected to the vehicle via the body control module. I have never used one in any swap. Just keep up with the oil level and you will be good to go...
T,
Old 08-02-2017, 02:05 PM
Thanks guys.
Old 08-07-2017, 06:30 PM
jasonz28camaro jasonz28camaro is offline
Yep, run without it
Old 08-08-2017, 02:02 PM
Thanks guys, I didn't plan on using it at all. I just wanted to confirm there was no plug for it etc.
