Old 08-15-2017, 06:40 PM
DT69Cam DT69Cam is offline
Default LS3 w TKO or T56 (What clutch/flywheel)
What clutch kit and flywheel you guys running with your LS3 ?? I have an LS3 and a TKO 600.
69 Camaro Convertible (LS3/TKO in the works)
Old 08-15-2017, 06:59 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
I have done 4 of these combos and I run the gm ls7 clutch and flywheel and they work great
Old 08-15-2017, 07:05 PM
That is the clutch I had and just found out from McLeod that I can NOT use this clutch with their TO bearing. The McLeod TO bearing will NOT function properly with the LS7 clutch.
Old 08-16-2017, 04:54 AM
tubbed69's Avatar
I always used the to bearing from Kreisler engineering.
