Old 08-17-2017, 02:45 PM
Jr's Avatar
Jr Jr is offline
Default Holley dbw question
Do all the Holley gurus,
I'm using the part number 550-623(24x setup for truck dbw). I want to change over the throttle body to a vette 90mm dbw unit. Does Holley use a different wiring harness for the gas pedal and throttle body? If they do, does anyone know the part number for the correct harness i need?
Thank you.
Old 08-17-2017, 04:06 PM
andrewb70's Avatar
This will do...
https://www.holley.com/products/fuel.../parts/558-406
Presumably you have a Dominator ECU...
Andrew
Old 08-17-2017, 08:31 PM
Jr's Avatar
Jr Jr is offline
That should be it. Thank you.
The Holley tech told me all the connectors are the same... he didn't believe that gm made a 8 and 6 pin connector for the throttle body.
Old 08-18-2017, 06:27 AM
andrewb70's Avatar
Holley tech isn't optimal for EFI support. To their defense, Holley doesn't sell a DBW harness for the older, 3 bolt TBs separately. It can be bought as part of a Terminator kit, which is how you have yours, I assume.
Andrew
