Old 08-20-2017, 04:48 PM
DT69Cam DT69Cam is offline
Default TKO, unable to mount to Bell Housing
I just spent all day trying to install my TKO 600 to my LS3 engine. I'm using an LS "621" Bell Housing and I could not get the input shaft to line up in the Pilot Bushing for nothing. Anyone have any ideas ???
69 Camaro Convertible (LS3/TKO in the works)
Old 08-20-2017, 05:44 PM
booah booah is offline
Just had this with a Mcleod set up, twin disc and one disc was backwards. May be the same thing.
Old 08-20-2017, 06:16 PM
Thx for the reply. I'm not sure what the hell the problem is. McLeod flywheel ram clutch. I can't seat the trans to the Bell Housing. Wondering if this BH is that much out.
Old 08-20-2017, 06:38 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Is your pilot bearing correct,not sure but I think there is a couple sizes,good luck
Old 08-20-2017, 07:23 PM
Sideshow Sideshow is offline
if everything is correct. we draw them in with the bolts. I know your not supposed to do it that way but all the ones that we've installed over the yeas have been done that way. just go slow. never had a ear break. btw.
Old 08-20-2017, 09:06 PM
JKnight JKnight is offline
I guess we should start with the simple stuff. You using a clutch alignment tool? Plastic or metal? Mechanical linkage? I had to depress the clutch a bit to get the input shaft to seat properly.
Old 08-21-2017, 12:52 PM
Ear broke off.
Old 08-21-2017, 12:53 PM
Hydraulic TO bearing, Ram clutch. Plastic alignment tool.
Old 08-21-2017, 02:05 PM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
Originally Posted by DT69Cam View Post
Ear broke off.
Just read through, and knew that was BAD advice!
Have you done a measurement of the OD of the input shaft and ID of the pilot bearing? Your sure the auto hub for the converter isn't still in the crank?! Have you slid the clutch on the input shaft to verify it slides easily and doesn't bind? For high rev or fast shift applications, before I install a unit, I usually apply a little valve lapping compound on the input spline of the transmission and then work the clutch back and forth to ensure it rides freely with no burs or nicks you can't see. Clean all of the compound off before reassembly.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
Old 08-21-2017, 05:06 PM
Thanks for the reply. Pilot bushing appears to be correct. Auto hub ? This is a brand new LS3. Oh boy, I never noticed an auto hub ?? I just installed the pilot bushing after removing the flexplate.
