Old 08-29-2017, 09:44 AM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Default Trans Crossmember
I know this has been beat around this forum before.... But I'll throw out the question anyway. 1970 Camaro, DSE subframe, DSE engine mounts, LSA w/ 4L80e trans. What seems to be the best solution for a trans cross member? I could just fab one up....looking for an easier (bolt in) solution. I know most guys are using a T-56..... anyone have any experience with a 4L80e??
Old 08-30-2017, 09:12 AM
BMR Sales's Avatar
BRP Hotrods has one!
http://www.brphotrods.com/products/2...cts/index.html
Should be similar to the TR6060 one I have in my '73
Old 09-07-2017, 08:10 AM
DKz Garage's Avatar
Thank you for the input..... I've done a lot of searching and the consensus is that the x-member is the same as a first gen?? I'll contact BRP Hotrods.
Old 09-11-2017, 02:19 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I had a hard time finding one that fit in my first gen. I tried the BRP mount, but it did not fit. I did find the G-force crossmember fit well in my first gen. I needed to shim the tail shaft up quite a bit to obtain a good driveline angle. Might be worth looking at for your second gen.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 10-06-2017, 02:23 PM
DKz Garage's Avatar
I took a look at the G-Force piece..... pretty beefy looking for sure! I'm thinking that any choice I make will require some tweeking....
Old 10-10-2017, 09:41 AM
BMR Sales's Avatar
Trans Cross Members are different from Gen 1 to Gen 2!
We make Crossmembers for the 1st Gen but not for the 2nd Gen, that is why I have a BRP item in my '73
TC
