Old 09-15-2017, 09:01 PM
Default 5th gen Camaro console mods
I'm putting a 5th gen console in my 69 Camaro with some direction from Jeff (jwcarguy) Thanks Jeff!
I decided to try my luck at making the mods to put an Auto Meter gauge pod in my 5 gen console. The console was mounted in the car to check the fitment of my B&M Stealth Pro ratchet shifter and so I could see the console cover on in place. I ended up trimming the change tray flush with the bottom where it started to turn in for the tray. I left the part you see with the orange tape for strength.
Make sure you measure there is room for the gauges and the brackets that hold them in. Your brackets to install the console might be in the way of the fitment. you can see my bracket if way forward so it's not in the way.
I'm going to show how I did my gauge pod install, I know there are probably better and maybe easier ways but here's what I did.
First I cut out the change tray from the console after measuring how much needed to be removed..
Then I measured and cut the gauge pod to fit the opening, and glued small tabs to hold it in place which I had to trim later.
You may want to do this step after you close in the hole with the ABS the check what you need to trim.
The tabs ended up being an unnessary step. I used them to hold small pieces I cut for around the gauge pod. I used a piece of ABS (Bought on E Bay) the same thickness as the gauge pod to fill around it to make it flush with the top of the console piece. The pieces on the under side were 1/16".
I filled in the whole opening with 1/8" ABS. I used a heat gun to roll the top to match the console cover then I marked what I needed to remove for the gauge pod and cut it out.
I could have just used long pieces of ABS 1/8" which I ended up using for the strips you can see from the bottom. Around the perimeter of the opening.
I'll post more tomorrow.
, most important thing Measure put witness marks and keep using them.
Old 09-16-2017, 09:14 PM
Then it was time to epoxy the pieces together. I used these epoxy's
The main one I used was the Permatex Plastic welder which I used on most of the pieces. The Permatex 5 minute epoxy is thin and what I used to fill in some fine spaces. But you could use body filler later on. The JB plastic weld is a two part stick you knead together and I used to fill some of the larger gaps.
And here is where I'm at all epoxied up and ready for a thin finish coat of filler to blend all the joints in.
Old 09-18-2017, 04:55 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
That's some nice work there buddy.
Curtis
Old 09-23-2017, 06:39 PM
Thanks Curtis!
I went by my buddy's shop (He will be painting my car ) to ask him to let me have some filler to finish it up. He says sure as he does with anything I ever need. He takes it fills it we start bull****ting, then he tells me to wait til it hardens, then he sands it down. I told him I'll do it he says it needs another coat put it on and sands that and primes it. He tells me to wait 3-4 day then water sand it with 600. Then he says bring it back and we'll paint it if you want.
Here's how it came out
So I can't say it was all me.
Old 09-23-2017, 08:03 PM
RdHuggr68 RdHuggr68 is offline
That looks great, cant wait to see finished project. Thanks for sharing.
Kevin
Old 09-23-2017, 10:00 PM
fleet's Avatar
fleet fleet is offline
Looks great Wayne...nice work by all.
Old 09-23-2017, 10:26 PM
Spiffav8's Avatar
Lateral-g Moderator
That turned out great!
Curtis
Old 09-24-2017, 12:36 PM
Thanks guys, I appreciate you checking it out. He suggested I do it in a semi gloss black like the 69 console so it would be a throw back to the original gauge pod for 69.
Old 09-25-2017, 08:05 AM
Goosesdad's Avatar
Goosesdad Goosesdad is offline
That looks awesome.
Have a great day!
John
My Build Thread:
https://lateral-g.net/forums/showthread.php4?t=53320
Old 09-26-2017, 09:51 AM
Thanks John! I'm trying.
