Old 10-04-2017, 10:33 PM
bergers59 bergers59 is offline
Default DSE flange to flange width vs stock
Does anyone know the flange to flange width of a stock camaro vs a complete DSE subframe setup. Looking to possibly change subframes without changing wheels.. As of right now, it's a tight setup so I wouldn't be able to play with spacers.
Old 10-05-2017, 05:33 AM
dontlifttoshift's Avatar
Stock is 60" hub to hub isn't it? That sometimes changes with various brake kits.
DSE is 59.5 plus the rotor hat thickness, so it is very close to the same.
What size wheels and tires do you have? What is the backspace.
Instructions here. http://www.detroitspeed.com/images/i...20Subframe.pdf
Donny
Old 10-05-2017, 03:58 PM
Never saw that pdf, that's everything I need, Thank you!
