Old 10-18-2017, 06:32 PM
Camaro684 Camaro684 is offline
Default 68 Camaro with TruTurn
This has already been ask but I could not find it. Sorry to ask again.
I have a 68 Camaro with a SB 383 non LS, T-56, PS, PB Disk, Hooker Super Comp headers, and the Ridetech coilover system
http://www.ridetech.com/products/sus...ilover-system/
I did not purchase the TruTurn because I didn’t think I needed it. It was only after having problem with the outer tie rods hitting the inside of the rims that I reread the instruction and I read that stock steering arms will not work. So I just purchased the TruTurn system.
The problem I am reading now is when you use the TruTurn system is that Hooker Super Comp headers will not work with it.
What headers is everyone running without have clearance problems and did you have to use a mini-started with it?
Could you add the part number with it with the headers you used and if your flywheel is 153 or 168.
I was looking at Dynatech but I have read they only work with 153 tooth flywheel and they have a couple of models for a 68 Camaro.
https://www.summitracing.com/parts/d...t/model/camaro
Thank you for the help!
Old 10-22-2017, 12:15 PM
Default This is the answer
Britt at Ridetech helped with the answer.
Just look at this link http://www.pro-touring.com/threads/9...tem-on-f-body-!!!!!
As soon as I put them on, I will post pictures.
