Old 10-21-2017, 06:22 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Default LS9 Flywheel
I am buying a new LS9 for my project and and still have to go pick it up but had a question,I have a new flywheel and clutch set up from my LS3 and was curious if it will work on LS9.Thanks for any help.
Old 10-21-2017, 06:45 PM
I think LS9 and LSA crank has more bolts than an LS3 I think it's 9 bolts. Not sure if the clutch will fit the flywheel.
Old 10-21-2017, 07:05 PM
tubbed69's Avatar
Thanks Waynie,I had not checked into yet but I was afraid it might not work.That means more parts for sale.
Old 10-21-2017, 09:43 PM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
ls1,2,3,6 6 bolt crank, lsa, ls7 8 bolt, ls9 9 bolt crank. clutch should be interchangeable with the the ls9 flywheel. key being "should" but depending on what ls3 clutch you have, may not hold up to ls9
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 10-22-2017, 06:12 AM
tubbed69's Avatar
Thanks,I have a good clutch setup,I will pick up a new flywheel.
