Old 10-22-2017, 04:10 PM
67_camaroRS's Avatar
67_camaroRS 67_camaroRS is offline
Default MOMO steering wheel on 67 Camaro
I'm currently looking into buying a MOMO "Race" steering wheel for my 1967 Camaro. Right now I have a Ididit tilt column with a grant wheel. What do I need to buy, to install this MOMO wheel into the Camaro? I've done little research and heard about NRG and etc. Thanks
Old 10-22-2017, 04:42 PM
I got NRG on mine and all works well. Will be two things you need to buy. The hub adapter and the quick release. Simple install and their site has all the part numbers you'll need.
I have he same wheel, same column, in my 69.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 10-22-2017, 05:17 PM
I just checked at the NRG website and looked for the short hubs for Camaro it said they only have 69-05, would that still fit the column?
Old 10-23-2017, 09:57 AM
BMR Sales's Avatar
I use a Quick Release from LTB Autosports in my '73
http://www.ltbautosports.com/ltb-qr-...e/g-84357.aspx
Old 10-23-2017, 11:33 AM
I have a 67-68 column in mine (didn't want key on column). Mine bolted up no issues.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 10-23-2017, 11:06 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
I have this on the shelf to be installed in my 67 can JWCARGUY has it in his 68. Both on GM columns.
Curtis
Old 10-30-2017, 10:21 PM
Thank You
Old 10-30-2017, 10:59 PM
MtotheIKEo MtotheIKEo is offline
I used the same NRG hub/adapter as Will. It worked great and feels solid.
Old 10-31-2017, 04:38 AM
pittpens24 pittpens24 is offline
Here is the one I got for my MOMO wheel. Worked perfect and looks kind of stock.
https://www.classicparts.com/1947-94...tinfo/IN-3643/
Should have noted that I have a '68 with a stock steering column
