Old 10-24-2017, 10:02 PM
1962nova's Avatar
1962nova 1962nova is offline
Default Tire size help
1962 Chevy II currently has 17x7 with 215/45/17 up front. I am getting new tires and I want to put a little bigger tire up front.
What would be the better pick, 225/45/17 or 235/40/17?
Thanks,
Kent
1962 Nova 2-door post. TCI IFS/4-link, 9" w/3.70, 383 w/ 579hp, 2004R......Almost done.
Old 10-25-2017, 02:24 PM
What is the rear tires. The 225/45 is slightly wider (10mm) and taller (9mm). The 235 is wider still but shorter than your existing tire by 5.5mm. All small differences so I'd see if you can fit the wider of the two options up front, and which has the better selection of tires available.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 10-25-2017, 04:00 PM
Flash68's Avatar
Flash68 Flash68 is offline
Ours has a 225/50/16 on the front with the same TCI IFS sub.
Your car sounds rad judging by the sig.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 10-27-2017, 11:33 AM
1962nova's Avatar
255/40 in a 17x8 got the rear
