Old 12-04-2017, 04:28 PM
camaro1969 camaro1969 is offline
Default 69 Camaro Rear Brake Conversion with Mini Tub Kit
My camaro has rear drum brakes; I would like to convert to disc brakes.
Details: My current rear set up has a dse mini tub kit installed, complete with offset shackles, rear crossmember support for shocks to be repositioned inside of the leaf spring. The leaf springs have a 2" drop. A DSE narrowed gas tank is also installed.
I have a 12 bolt rear with posi. I have not removed the back casing to see whether it has a C clip eliminator.
Question: I am looking at different options from wilwood to american brand conversion kits. I do need to have the parking brake, and want to know the following.
1. do I need to have a disc brake with a drum combo to accommodate the parking brake? Brakes seen here http://www.wilwood.com/BrakeKits/Bra...o=140-11398-DR
1a. Does installing this add more of a positive wheel offset, adding more back spacing by pushing the brake assembly further out towards the street?
1b. Does installing this kit give me everything I need to convert from drum to disc, appears the calliper attaches to the drum assembly (Refer to image below).
2. I assume that since I have the DSC mini tub kit installed, I do not have to worry about staggered shocks?
3. This is an example of the american brand rear brakes. Will these accommodate a parking brake (i assume no?)
https://www.ebay.com/itm/GM-10-12-Bo...BSw3Iw&vxp=mtr
4. Lastly, I have not fully decided whether I want narrow my rear end (to accommodate larger rear tires), and if I do, does that change anything with the install of which conversion kit i use.
Vic
Old 04-20-2018, 11:30 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
My bird is mini tubbed has the stock LS1 F-body rear brakes 12"x1" rotors no need to worry about shock stagger and they bolt on 10-12 bolt housing ends I didn't use a spacer like some say are needed to center the rotor in the caliper.
biggest issues were figuring out parking brake cables and adapting the brake lines
simple cheap and effective
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 04-20-2018, 12:31 PM
ADY's Avatar
ADY ADY is offline
Reach out to Tobin at Kore3.com (sponsor on this site), he can answer all your questions and set you up with a package that will work.
-Adam
1968 Camaro SS
