Old 12-20-2017, 05:32 AM
AB69Z AB69Z is offline
Default Ls3 to Ls7 switching over components
I have the Ls3 installed and fully dressed and am now upgrading to an Ls7 (Wet Sump)
Will all the accessories bolt right on and function properly
Coils
Sensors
Starter
Headers
Vintage air front runner system ( water pump,ATI damper,pulleys etc... )
Valve covers
Oil filters ( I bought a bunch )
Lingenfelter oil line block
Old 12-20-2017, 12:38 PM
Che70velle's Avatar
Yes, all will work with you going wet sump...did you change cranks? The damper may or may not, being as how the ls7 crank has a different snout... However, you should consider upgrading your headers, unless your using a set of 1 7/8”’s or larger. The ls7 needs help in the exhaust area to maximize its efficiency.
Thanks Dad!!
Old 12-21-2017, 03:52 PM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default lS7
Now ... what idiot would have talked you into switching to an LS7 !!??
LOL
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
Old 01-21-2018, 02:38 PM
ProServ ProServ is offline
Default Sensors
The LS3 MAP sensor may not be a direct fit due to the different mounting method and hole bore diameter compared to the LS7 (depending on the year of the LS7 intake manifold if I recall correctly).
Are you just changing the heads and intake? If so, what size bore engine?
If you are changing to a wet sump LS7 complete engine I assume it is a crate engine someone built using an LS7 block and heads but aftermarket wet sump crank.
Either way (existing LS3 block or LS7 block) all the other things you mentioned should fit without any issue.
You should check exhaust flange and gasket fitment. The LS7 ports are different from the LS3 ports and it is possible to have a gasket and flange combination that seals on an LS3 head and doesn't seal properly and/or has gasket into the port on an LS7 head. Just check and if needed change exhaust gaskets. Depending on how big the engine is (I assume it is a 427) and the camshaft/RPM range you may benefit from 1-7/8" headers if you don't already have them but you don't have to change headers.
Coils
Sensors
Starter
Headers
Valve covers
Jason Haines
Product & Service Solutions LLC
[email protected]
www.proservsolutions.com
http://stores.ebay.com/productservicesolutions
