Old 12-24-2017, 12:28 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Default Ls9/tko 600
Is anyone running this combo?If so which bellhousing and clutch setup are you running,thanks for any help
Old 12-28-2017, 12:44 AM
gnx7's Avatar
gnx7 gnx7 is offline
do you yourself a favor and plunk down the money for a T56 Magnum.
They are stronger, shift waaaay smoother, will actually shift at high RPM, and offer many shifter positions.
I've pushed one to well over 1000rwhp for 2-3 years without issues behind a turbo'd LS9 longblock. Shifts at 7800rpm without any issues 1st thru 5th gear. I run a Quicktime BH, Mcleod flywheel, RXT HD1200 clutch
