Old 01-18-2018, 06:42 PM
johnnymac46's Avatar
johnnymac46 johnnymac46 is offline
Default TIG Cups
I have a question for the TIG welders.
I recently purchased a Miller Dynasty 200 SD(just the box nothing else) for dirt cheap, and am working on getting it set up. I've picked up a torch, pedal, ground clamp, argon tank, and am currently borrowing the regulator off my MIG Millermatic 211. I have some consumables, tungsten in various sizes (red tip for now) and some steel filler (about 2 pounds of assorted ER70S6).
I've dabbled in TIG welding and have a basic understanding, my question is what are your most commonly used Cups, and what are your preferred? I.e. Pyrex, clear, custom made?
I would like to find a decent assorted kit to get started with that I can build off. I do basic fab, nothing crazy, body panels, exhaust, maybe the occasional thicker metal (1/8-1/4)
Old 01-19-2018, 08:28 AM
Yelcamino's Avatar
Yelcamino Yelcamino is offline
I recently bought this kit from Weldporn. I haven't used all of them yet, but it's a nice assortment for not a lot of money.
wsi-imageoptim-IMG_82611-510x600 by Yelcamino, on Flickr
I also have this one from Weldporn and I really like it. However, dropping it makes for a bad day!
wsi-imageoptim-IMG_2471-510x600 by Yelcamino, on Flickr
Herb
1966 El Camino LS408/T56Magnum
1966 Chevelle 509/T56Magnum
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 01-20-2018, 03:10 PM
Once you use a see thru clear cup -- hard to go back to a standard ceramic....
Old 01-20-2018, 03:53 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Clear cups are very cool... and very fragile for clumsy dipsh!ts like me.
Look into gas lenses, an upgrade from a standard cup setup.
Jeff-
Old 01-20-2018, 04:07 PM
Johnny ----
The thing that is SO different from MIG is that TIG is all over the map --- the cup sizes etc just "depends" -- depends on what you're welding the gas flow required - are you doing an inside corner with a bunch of stick out - or an outside corner on real thin materials.....
You'll need a bunch of different cups - various torch sizes - various fillers.... as you get along in this world (of TIG).
Basic cups - #5 / 6 / 7 / 8
Basic fill - ER70S-6 for mild steel --- 308L for stainless -- 4043 for Aluminum
Get some 1 1/2% Lanthanated 1/16th dia for (1/8th" and under material) and 3/32th for 1/8th and thicker -- it's good for AC (alum) and DC (all else)
GET A GREAT --- not just good enough --- GREAT auto darkening helmet
Old 01-20-2018, 07:36 PM
Johnny ----
I ordered a set of assorted cups, and a few clear cups. It will get me started and I can get to building the toolbox of TIG stuff.
I have an autodarkening helmet from miller I have had for a few years I believe the "Elite".
Should be entertaining to get into it, I've got a 57 Chevy truck that needs a lot of body work I'll get plenty of practice on.
Thanks for the help everyone! I'm sure there will be plenty of questions in the near future.
Old 01-20-2018, 07:39 PM
Welding tips and tricks . com has lots of good YouTube videos worth watching
Old 01-21-2018, 10:41 PM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
Look into the Furick cups to add to your assortment.
Jose
Old 05-23-2018, 05:48 PM
jarhead's Avatar
jarhead jarhead is offline
Jeff-
I had to look up what a GAS lens was...
Getting ready to order a TIG and doing some research.
Thanks Jeff
joe
Semper Fi
My 68 Torino
Old 05-24-2018, 08:30 AM
RDuke RDuke is offline
This.
