Old 02-06-2018, 05:46 AM
Trick-Tools.com's Avatar
Trick-Tools.com Trick-Tools.com is offline
Default Trick-Tools = Fein RS12-70E Professional Pipe Polisher video
The Fein pipe and tubing polishing tool is perfect for finishing all types of ferrous and non-ferrous metals. Especially useful in the stainless handrail industry, this unique tool allows the user to remove weld seams, sand scratches, and polish to a satin or mirror finish. The flexible grinding belts conform themselves perfectly even on sharp curves allowing the entire tube surface to be polished in a full 180 degrees.
SPECS
•Motor: 750 Watt Output
•Belt Width (inches): 1-9/16 , 13/16
•Belt Length (inches): 32-1/16
•Belt Speed: 72 ft/sec
•RPM: 2,700–7,000
•Weight (pounds): 9
INCLUDES
RS12-70E pipe polisher
Heavy duty carrying case
(10) 13/16 inch 120 grit belts
(10) 1-9/16 inch 120 grit belts
(10) 13/16 inch 180 grit belts
(10) 1-9/16 inch 180 grit belts
(5) fleece polishing belts
for more information visit http://www.trick-tools.com
Brycen Smith
[SIGPIC][/SIGPIC]
