Old 02-13-2018, 01:08 PM
Default 9" pinion yoke Question
Pinion yoke question, does a Ford 9 inch rear and have to be reset if you want to change the yoke? It’s brand new never been broken in.
When you install a CV driveshaft does it matter which end the CV joint goes on when you have it built if the angles are close on both ends?
Old 02-13-2018, 02:04 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Depends on where the rear end was sourced. I know many of them use shims/spacers, rather than a crush sleeve, so there is just a torque rating and that's it.
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 02-13-2018, 09:08 PM
Thanks Dale.
