Old 02-28-2018, 01:00 PM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Default Oil pan
Running an LSA in my 70 Camaro Build with a DSE sub-frame. IS the Holley oil pan a good choice for this set up? I ran the Holley pan on my last build, 69 Camaro w/stock sub - it worked out great.
Old 03-01-2018, 12:46 PM
The newer design (302-2) is the way to go. The 302-1 pan JUST touched the rack in my 69 with DSE frame.
LSA should be able to use the 302-2 no problem, but check to be sure (I didn't and didn't realize it didn't clear my 427 crank). Glad I spun mine to check!
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 03-01-2018, 07:36 PM
Che70velle's Avatar
I think that the newer 302-3 pan is designed for a 4” stroke. I’m not sure about the outer dimensions, concerning fitment however.
Thanks Dad!!
Old 03-08-2018, 10:54 AM
gnx7's Avatar
gnx7 gnx7 is offline
I would also check out AutoKraft as their pans have built in baffles/trap doors. That's what I'm running on my Chevelle.
Old 03-09-2018, 02:20 AM
65 Drop Top 65 Drop Top is offline
Check out the dimensions of the Mast oil pan. Comes with a cast in baffle too.
Old 03-09-2018, 04:55 AM
rickpaw rickpaw is offline
External dimensions on the 302-3 are identical to the 302-2 pan, other than the front corner notch to the sump to clear the mustang k-member. Besides the 4" stroke clearance, it has turbo oil drain plugs built to the sides. Those are the main differences.
More info on ls1 tech.
https://ls1tech.com/forums/conversio...ew-thread.html
Tu Ho
Old 03-15-2018, 01:33 PM
DKz Garage's Avatar
Thanks for the input everyone. I was looking at the MAST 401-011, which is the one DSE mentions on their site as compatible with their Sub frame. Anyone have any experience with this pan??
Old 03-18-2018, 09:19 PM
I just bought a Mast oil pan. I'm running a different set up as you though, I have a 55 Chevy with a LS3 and an AME chassis, so I can't help you with fitment. I was looking at the Holley pans also. I went with the Mast pan mostly because it has a baffle cast into it and comes with a baffle cover. Stock windage tray also fits inside. The Holley pan you have to purchase the baffle separate for another $200 or so. It'll fit a stroker crank if ever needed also.
Old 03-18-2018, 09:31 PM
And here is a couple pictures of the Mast oil pan for reference on depth, compared to a QuickTime bell housing. The oil pan is ~ 1/2" shorter.
Old 03-19-2018, 07:54 AM
DKz Garage's Avatar
Thanks for the pics! ..... This looks like the ticket! I am running a quicktime as well..... time to get the pan ordered!
