Old 03-02-2018, 07:19 PM
dadlts dadlts is offline
Default gen2 camaro LS procharged acc drive bracket for ac wtd
Hi Gents , I have a 72 Camaro with a lq4 ls with a passenger side mounted procharger and a truck accessory bracket so the procharger is mounted on the passenger side with no room for a ac compressor (I want to add a vintage air system) so I think I will need to move the procharger to the driver side and alt to the passenger side to make room for the compressor,
so far "procharger" or "vintage air" has not come up with a solution for me, I hope some one here has done this or can steer me in the right direction
thanks for your help
Old 03-03-2018, 05:57 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Give Wayne a call at Kwik Performance........He makes a low mount passenger side mount for a Sanden SD-7 compressor........Similar to the following picture..........tucked in and down low.......Wayne's unit has a belt tensioner built into it unlike mine which uses a turnbuckle for tension......
Ken
