Old 03-12-2018, 08:36 AM
Trick-Tools.com's Avatar
Trick-Tools.com Trick-Tools.com is offline
Default Proline Portable Planishing Hammer
The ProLine Portable Pneumatic Planishing Hammer is designed for forming and smoothing compound curves in sheet metal. It is used in many industries, including automobile and aircraft restoration, race car fabrication, sheet metal stamping shops, artistic applications, etc. A ProLine planishing hammer takes the work out of metal work and saves the metal worker hours of time, leading to increased production.
One huge advantage with the design of the ProLine hammers is the foot pedal activation. By pressing the foot pedal down once the material is in place, you bring the dies together and start the air motor in one step. This not only allows for easy removal of your part when open, but gives very precise control of the pressure and allows for feathering off at the end of a shape. This is not possible with most planishing hammers that have a fixed die gap.
This portable unit features a heavy cast base that absorbs vibration and gives a stable work platform while the tip back wheels make it easy to move around the shop. The purpose built air motor head can be easily removed to fit an optional hand-held yoke or this unit can be converted to a hand-held hammer for use off of the mounting stand with an optional hand trigger. ProLine hammers use CP style tooling.
ProLine planishing hammers are completely fabricated in the USA. If you are looking for quality, then you have found the finest planishing hammers made.
https://www.trick-tools.com/ProLine-...g-Hammer-11537
Warranty:
1 year manufacturer's warranty
Specs:
•Throat Height (inches): 12.375
•Throat Depth (inches): 22
•Radius (inches): 3, 12, 36
•Air Consumption: 0-6.5
•Air Pressure: 125 psi
•Weight (pounds): 300
Includes:
Upper die
3R, 12R and 36R lower dies
Die extraction tool
Dead blow mallet
Oil and special oil bottle
Stainless steel engraved die rack with grommets
Air regulator and oiler assembly
Brycen Smith
[SIGPIC][/SIGPIC]
The Following User Says Thank You to Trick-Tools.com For This Useful Post:
camcojb (03-12-2018)
Old 01-07-2019, 07:01 AM
OPTIONAL TOOLING:
ProLine 18 Piece Planishing Hammer Die Kit
dies made from polished and hardened S7 tool steel. The 18 piece kit completes the full set of available dies when purchased with any ProLine Planishing Hammer.
2.375 OD flat face top die
1.5 OD reverse curve top die
1.5 OD lower bottom dies (.78, 1, 1.5, 2, 4, 5, 6, 9, and 24 inch radius and flat)
2.0 OD lower bottom dies (12, 24, 36 inch radius)
Linear stretch die
Rectangular die (.875 x 2.5; 24R x 4R approximately)
Square die (flat with one edge .3R approximately)
ProLine Cast Aluminum Hand-Held Planishing Hammer Yoke
ProLine Tubular Hand-Held Planishing Hammer Yoke 90-120-60
ProLine Tubular Hand-Held Planishing Hammer Yoke 90-90-90
Brycen Smith
[SIGPIC][/SIGPIC]
