Old 03-15-2018, 08:23 PM
67RSRAG's Avatar
67RSRAG 67RSRAG is offline
Default C5 Slave cylinder with t56 magnum
Any one use a OEM C5 slave with the t56 magnum instead of gen 4 with success?
Any difference? will it work? going to be using it with an LS7 clutch. and a OEM Gen 4 Master Cylinder.
Old 03-16-2018, 04:15 PM
gnx7's Avatar
gnx7 gnx7 is offline
You need to run an Fbody pilot bearing AND slave cylinder.
You can certainly try it.... but it isn't going to work.
Remember the factory LS2/7 steel flywheel is one heavy SOB. You may want to run a Fidanza LS2 alum instead if you don't want it to rev like a dump truck.
Old 03-16-2018, 07:24 PM
67RSRAG's Avatar
I have read conflicting opinions. I want to try the LS7 stock package and if I don't like it I could always switch it out for an improvement. At least I could have a before and after feel. Also with a 4;11 gear the heavy clutch might not be that bad.
As for the Slave the only difference is the extended braided line from what I can find from my research. Has anybody tried it?
