Old 03-27-2018, 10:05 AM
prolificdesigns prolificdesigns is offline
Default 69 camaro dash
what modifications are needed to put a nova dash pad in a 69 Camaro? im wanting to remove the clock bump out in the Camaro dash to fit a holley efi dash in DSE dash. it would look much cleaner if the dash pad was just flat and didn't have the clock bump out.
if somebody has done it and has pictures that would be awesome.
Old 03-28-2018, 07:33 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default Nova Dash
yes, I did it ...
Starts here
https://lateral-g.net/forums/showthre...Intense&page=3
let me know if you have any questions
Cheers
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
Old 04-01-2018, 10:24 PM
Awesome build, looks like you had to modify the top right corner of the dse dash to make it have smooth transition, is that all. Also I've read I'll also need nova a pillars is that correct too.
Old 04-02-2018, 05:30 AM
Sheck44's Avatar
Default Thanks
Yes, using the nova dash pad there will be a gap on the top right, we also modified the nova pad to extend down into that corner as well. Also, we extended the connection stud on the back so we could get a good amount of stud to connect ... VERY tight fit and you want to pull it in for a proper fit.
We used TMI pillars ... also VERY tight but we messaged it to fit
Cheers
Steve
73' FJ40 LS - SOLD
911 Hotrod - SOLD
2002 Gated 360
