Old 04-04-2018, 01:17 AM
medbali76 medbali76 is offline
Default low mile supercharged LSX 427 for sale
Item Location (City/State): Hungary
Price: as supercharged turn key package: 20300 EUR
see more below
Description:
Up for sale is a used 7.0 LSX engine, built for racing or for high performance street use. (Approx 1000-1200miles in the engine.)
Due to the costs to ship it back to USA this is mainly for European pro tourers, racers,drifters etc.
LSX 427 (7.0L) iron block, 9.9:1 compression ratio
Callies Dragonslayer LS dry sump forged crankshaft
Callies Ultra Timken steel H-beam connecting rods
Wiseco forged pistons with upgraded heavy duty tool steel piston pins
Total Seal rings - setup for 10-20 psi boost
Calico coated Clevite bearings
PRC LS7 CNC heads, titanium intake, stainless exhaust valves, PSI valve springs, Ti retainers
CNC machined billet valve covers
LSX multilayer head gaskets
ARP 6 bolt head studs
LSX main bolts
Ported LS7 intake manifold
Ported 92mm GM throttle body (you can swap it to a mechanical TB)
Custom cam by CamMotion (230/248 .634"/.634" 116LSA +4) (designed for centrifugal superchargers)
Johnson SLR (slow leakdown rate) lifters
GM dry sump oil pump
GM dry sump Corvette oil pan with -12AN adapter
Peterson dry sump tank and breather, -12AN hoses
Mighty Mouse catch can for forced induction
GM LS7 ignition coils
MSD spark plug wires
ATI dry sump crank pulley /w ARP bolt
Trick Flow coolant crossover
FIC 850cc flow matched injectors
Billet fuel rails
all sensors (cam, crank, knock, coolant, oil pressure, 2bar MAP)
GM LS3/LS7 water pump with 180 Fahrenheit thermostat
GM starter
TCI heavy duty flexplate /w ARP bolts
(The long block can handle up to 1200 HP)
price: 15.500 EUR
Turn key package avaliable!
Tuned GM E67 engine control module, standalone wiring harness, Paxton Novi 2200 centrifugal supercharger, brackets, pulleys, alternator, power steering pump, Treadstone 1450 CFM intercooler, Alkycontrol methanol system, Turbosmart Big Bubba blow off valve, AEM failsafe AFR gauge, Walbro 450lph E85 compatible in-tank fuel pump.
Approx 900 Hp and 1100 Nm of torque at only 12 psi of boost! Ideal for pro drifting, or for street/strip. The engine is almost new, only 1500-2000 kilometers of street usage and two shakedown ¼ mile runs, with a safe tune (16 degree timing, rich AFR) Best ¼ E.T. 10.05@224km/h (1750kg street car on radial tires)
Price with the turn key supercharger option: 20.300 EUR
