Old 04-14-2018, 08:55 AM
kevin_l's Avatar
kevin_l kevin_l is offline
Default Power steering hard lines
Hey guys looking for some advice or help finding a solution for PS lines on my chevy II. I am running a dse sub and stock F body accessories. I purchased the dse hose kit but since I am running a stock ps pump and not the vintage air front runner type my routing isn't as cut and dry. I am wondering if I can make some hard lines to get the hose fittings in a better location. But can I use annealed stainless and AN flares or will that not hold the PSI. I am open to suggestions as I am out of ideas.
If I could just get the return fitting up a few inches I think I could make the dse hose kit work. But other than running a AN extension I can't find a taller adapter.
Old 04-14-2018, 02:15 PM
kevin_l's Avatar
Something like this ok for the return side only?
Sent from my SM-G892U using Tapatalk
Old 04-15-2018, 09:48 AM
dontlifttoshift's Avatar
That will be fine.
Donny
