Old 08-20-2006, 06:02 PM
ElcoMan ElcoMan is offline
Lightbulb an all wheel drive pro touring blazer
i just picked up a first gen chevy blazer and now i woundering what do with it. everyone i know tells me that i should put a 6 inch lift and all that other off roader stuff. but i was thinking about......
1- an all wheel drive unit for the ss silverado
2- morrison g max chassis
3- ride tech air bags
4- massive 20 and 22 inch extra wide wheels (10 and 12)
5- blown efi 540 engine
6- manual transmission
Old 08-20-2006, 08:38 PM
hiwayman hiwayman is offline
yea man all the abve that will look sick!!!
Old 08-21-2006, 09:29 AM
syborg tt's Avatar
If you plan to go AWD - you may want to jump over to the syty forum to pick up some pointers
AWD & Manual Tranny don't last long. So far the 4l80e has lasted the longest. Don't ever consider a 700rr as it can barely hold 300hp
Also being AWD you have to consider tires heights. If you opt for different height you have to play with the gears front and rear so you don't smoke the transfer case.
?? didn't know that Art Morrison had a design for the AWD chassis.
If you go AWD - make sure you use ladder bars in the rear if you want traction at the strip as this seems to be the only combo that actually works.
Good luck with the project and i can't wait to see pics
marty-mj
Old 08-23-2006, 09:07 PM
T Bell T Bell is offline
4,5,6 maybe 3
