Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 05-05-2018, 09:22 AM
454SSguy's Avatar
454SSguy 454SSguy is offline
Default 454 ss
What's up, been around a while just mostly lurking. I've been building this truck for the past 4 years or so with some hiccups along the way. I think I've got most of the issues lined out at this point. Motor is going in later this month.
I'm hoping to get to do some AutoX/roadcourses (I don't really know the difference) later this summer and was looking for a few pointers so I don't look like a complete fool when it get out there.
1st - is anyone in here local to Okc that has info on any events near here.
2nd - is there anything in my build that seems unsafe or a showstopper before I start (basic build listed below)
3rd - New tire setup (any recommendations on size and compound)
4th - suspension setup. Everything is semi adjustable but I don't really know where to start. It has alot of variables.
This truck was built slow and on budget, I think it will be a fun street toy but I'm not really sure how great it will do on a track.
The build is
90 454 SS Pickup
Engine is 498 CI BBC
12.7:1 Comp on E85
Estimated 675-725 at the flywheel
Trans - T56 from fbody built by tick(stg 3)
Suspension
Front- Single adjustable coilover with 450lb spring. Factory control arms with polybushings. 1 5/8" hotchkis swaybar in poly/aluminum mounts
Rear- Homebuilt adjustable 4 link on single adjustable coilovers on 150lb springs. Chassis mounted watts linkage from Fays2, boxed chassis.
Front is factory size drilled rotor, stock caliper.
Rear is factory Eldorado rotor and caliper
Wheels are Cragar 397 steel and heavy
Front - 17x8
Nitto NT450 size 275/45r17
Rear
17 x 11.5
Toyo Proxes size 345/40R17
Will post pictures later...
Sent from my SM-G950U using Tapatalk
Old 05-13-2018, 08:54 AM
z28cp z28cp is offline
I am not local to you, I'm up in Nebraska, but here is a link to the local Oklahoma SCCA group for info on local Autocross and Road Racing events. There is a 2-day Autocross coming up on May 19-20 that you may want to check out. It is being held at Remington Park.
www.oksccs.org
The Following User Says Thank You to z28cp For This Useful Post:
454SSguy (05-16-2018)
