Old 05-15-2018, 08:58 AM
732ndgen 732ndgen is offline
Default hydro boost or??????
building my 69 as soon as it gets out of paint jail and get the lt-4 motor back from wegner performance.my question is should I go to a stock type of master booster or go to a hydro boost system. any info would be greatly appreciated.
Old 05-15-2018, 06:37 PM
65 Drop Top 65 Drop Top is offline
The only issue I know of with hydroboost is that they can cause your brakes to be overly sensitive, they don’t modulate like a manual brake system would. But for a nice driver, who wants a light, powerful pedal it is a great system.
Old 05-15-2018, 08:27 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
I will be running the hydro boost setup. Jeff has it in his car and I am very impressed with it. No issues what so ever. Buy it, install it and you'll be happy.
Curtis
Old 05-15-2018, 10:00 PM
JKnight JKnight is offline
Given that you’re running an LT4, are you using the Holley/Stielow-pioneered solution to mounting a power steering pump? It may be obvious but hydro boost requires power steering.
Old 05-15-2018, 10:34 PM
Default brakes
wegner performance produced my front drive, so ill have power steering.they make the front drive for for dry sump or wet sump.
