Old 05-20-2018, 11:50 AM
wyattroa wyattroa is offline
Default Weld RTS 71 wheels
Just curious, I have Baer 6p 14" brakes on the the front of my chevelle. When looking for the weld RTS-71 wheels, they give the option for high, medium, and low pad heights. I was going to buy a pair on summit with a coupon, but it seems the only option is low or medium. Would these work on the baer brakes are do they require a high pad option?
1966 chevelle - Basket Case
https://lateral-g.net/forums/showthread.php4?t=54993
Old 05-20-2018, 07:56 PM
kevin_l's Avatar
kevin_l kevin_l is offline
Best bet is to call weld, I have the low on the rear and mid on the front using base c6 brakes with no clearance issues. And if you want the high clearance call summit, I am sure they can get them for you. They don't stock the wheels are are made per order.
