Old 06-24-2018, 04:47 PM
jasonz28camaro jasonz28camaro is offline
Default Camaro door hinge rebuild kit
Can anyone recommend a good door hinge replacement kit for a 68 camaro?
Also, I have seen some videos on youtube showing people only replacing the top hinge bushings, is this the norm or are they possibly just not showing replacement of the bottom?
Old 06-24-2018, 08:23 PM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
Just check with most of the aftermarket suppliers such a Classic indrustries
Old 06-25-2018, 07:37 AM
F'in mine's Avatar
F'in mine F'in mine is offline
http://www.heartbeatcitycamaro.com/s...Kit-16-Pieces/
1969 Camaro SSRS
Simon
Old 06-25-2018, 09:09 AM
ADY's Avatar
ADY ADY is offline
Got mine at Camaro Central: https://www.camarocentral.com/1968_1..._p/dwn-524.htm
I had a bodyshop put them on after watching install videos and not having the space in my garage, nor an extra person to help... best $250 I've spent in a long time.
-Adam
1968 Camaro SS
Old 06-25-2018, 02:31 PM
Thanks guys for the recommendations. I had Heard some kits were no good for some reason.
Do you guys do both the upper and lower hinges?
Old 06-25-2018, 07:37 PM
Zspoiler's Avatar
I did both upper and lower with a kit. Its a 1979 Z-28 RS with power windows so you know they were worn out.
Old 06-26-2018, 01:15 AM
Good deal thanks.
Any tips on instilling them? I havent Really looked into it, I’m assuming just take the door off and change them or is there a more efficient way to do it?
Old 06-26-2018, 12:23 PM
ADY's Avatar
ADY ADY is offline
I'd replace both upper and lower pins and bushing if you have the doors off... the kits are cheap compared to time invested in replacing the old upper/lower in the near future.
Here is a video that shows the steps that I found: https://www.youtube.com/watch?reload=9&v=jgrSA-gdjx4
-Adam
1968 Camaro SS
Old 06-27-2018, 06:14 PM
Zspoiler's Avatar
It would be easier to have help doing it.
Old 09-21-2018, 09:45 AM
130fe 130fe is offline
Post
I am having the same kit that Adam listed above installed by a buddys shop. will let you know next month when I get the car back how they are. Both of my bottom rollers are messed up.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
