Old 07-31-2018, 04:56 PM
Cunning69 Cunning69 is offline
Default Front Suspension questions
First, let me say that I know you should stay with one manufacturer for all of your suspension pieces. But through Craigslist and some sales I have the following ready to install:
RideTech UCA’s - extra 2 degrees of positive caster
Hotchkis 2-inch lowering springs
Viking dbl adjustable shocks
CPP AFX spindles - I” taller than stock
Already installed:
Hotchkis 1.5-inch lowering rear springs
What I need is a pair of LCA's, if RideTech had one for coil springs I would get it, so I am looking for suggestions for LCA’s. I am cheap so I want to use the pieces I already have.
I am leaning towards:
Global West – stock suspension specs
SpeedTech – additional 4 degrees of caster
Now for the questions:
For street and spirited driving, would 4 more degrees of caster be worthwhile?
Using the SpeedTech, will the wheel still be centered in the wheel well?
Is there something else I should be considering?
Thanks for the help.
1969 RS Camaro
Old 08-08-2018, 11:20 AM
David Pozzi's Avatar
Are those shocks coil overs?
If the adjusters are on the bottom, you will have a tough time reaching them with a lower arm made for stock springs.
I'd go with the Speed Tech for more caster. You want to have 6.5 to 7 deg positive.
http://www.PozziRacing.com
