Old 08-23-2006, 03:59 PM
camcojb camcojb is offline
Default Malitude 377 twin turbo engine for sale
Has approximately 100 miles on it since being assembled by Wheel to Wheel. Will be complete from pan to throttle body, including the Electromotive Tec 3 EFI system with coils and W2W custom stainless turbo headers.
Dart block
Callies crank
Oliver billet rods
Pro Topline 23 degree aluminum heads
Crower stainless roller rockers
W2W custom turbo grind cam
Holley Stealth Ram and throttle body
65# injectors
Vintage Air front runner system complete with alternator, ps pump, a/c pump
Powermaster starter
Electromotive Tec 3 system with sensors (you will need a new harness) info here: http://www.electromotive-inc.com/products/tec3.html
Basically you supply the turbos, wastegates, fuel system, and wiring harness $350) and this is a turn key deal. Already tuned.
Cost to build would be app. $20K.without turbos, and about $25K with. Like new, approximately 100 miles on it. I'm going to put my turbo LS2 in the car or else I would keep it. Runs excellent and very strong. Should be in the 800-850 HP range at normal street boost levels with the ability to turn it up for the track.
Option 1: $12,500 complete. Turbos, wastegates, and downpipe not included.The Vintage Air unit and Tec 3 are $4500. alone plus the custom W2W headers are several thousand dollars.
Option 2: $16,000 with turbos, wastegates, and downpipe. The Innovate liquid cooled ball bearing turbos are $2000 each plus $350 each for the wastegates. That would be $17,200 plus the wastegate plumbing if you bought them separate from the engine, so you'll save another $1200. as a package.
Old 08-23-2006, 06:41 PM
BRIAN BRIAN is offline
pm sent
Old 08-23-2006, 07:12 PM
Steve1968LS2's Avatar
Wait... when did you buy Malitude??? Damn, must of missed that one.. lol
Old 08-23-2006, 07:37 PM
Damn True's Avatar
Damn True Damn True is offline
Dear Santa,
Please see the above.
True
Old 08-23-2006, 08:34 PM
Musclerodz's Avatar
What is going in its place?
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-23-2006, 08:51 PM
ohcbird's Avatar
ohcbird ohcbird is offline
Exclamation
Holy Shiite Batman- somebody needs to jump on this... Unless you're 'in the industry' you aren't even going to come close to duplicating this for 12.5K. Think of the $$ in all the plumbing, machining, etc.
Assuming you could get two turbos ($1K each, 1.4K if ball bearing), the two wastegates ($600 for both), and get some stainless downpipes made- ($500 w/ Vbands welded on). That would be a twin-turbo mill with TONS of power for under $16K.
And for those that don't know our gracious admin- he is one hell of a guy to deal with. I bought a trans from him last month; it arrived in packing that the MARS lander would have been proud of.
Old 08-23-2006, 08:59 PM
Mike
My 402 LS2 turbo engine from the GTO. Just modernizing it a bit.
I have plans for this car, hopefully should be cool. I'm way ahead because of the awesome engineering that Mark did when he built it, so I don't have to do the big dollar stuff. There is nothing wrong with the current engine, it is brand new, built by a great builder and runs very strong even at low boost. But since I have this other engine and wasn't able to sell it unless I wanted to give it away, and the LSX engines are very cool I've decided to go ahead and swap.
Old 08-23-2006, 09:00 PM
Thank you sir, much appreciated!
Old 08-23-2006, 09:01 PM
4mm 4mm is offline
Damn Jody, you have been quietly working hard on this one. I never would have thought of swapping the engines.
Old 08-23-2006, 09:03 PM
As you know, I'm a bit unstable!
