Old 09-19-2018, 04:24 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Default New: Hellcat Supercharger Intercooler Manifolds - Billet
Schwartz Performance is excited to announce a new product we've developed specifically for the Hellcat/Demon superchargers.
Hellcat Supercharger Billet Intercooler Water Manifolds by Schwartz Performance
Make your Hellcat swap a little easier by ditching the large cast intercooler manifold on the factory Hellcat / Demon superchargers, and replace with our exclusive billet adapters!
Our low-profile manifolds are over an inch shallower than the factory Hellcat piece, NOT INCLUDING the pesky temp sensor that sticks off even further!
With our manifolds, you can choose your own path for the intercooler hoses, and use #10 AN hose instead of ugly rubber hose or attempting to adapt factory hoses. We allow use of the factory temp sensor and bleeder valve for OE functionality.
Our base kit includes:
-(1) LH and (1) RH billet aluminum manifold
-(4) #10 AN to O-ring adapters
-(1) #10 AN to NPT fitting adapter for temp sensor
-(1) 1/8″ NPT allen plug
-(1) #10 O-ring low profile allen plug
OPTIONAL ADD-ON:
-(2) Assembled #10 AN hoses for connecting the two manifolds together
***You will need to furnish the in/out side of the manifolds to your reservoir/pump/heat exchanger using #10 AN O-ring adapters of your choice.
Straight or 45 degree swivel adapters will work, with a 90 or 45 degree hose end attached.***
ITEMS TO REUSE OR SOURCE FROM A PARTS STORE/DEALER:
-(1) Mopar water temp sensor
-(1) 1/8NPT bleeder
-(4) Torx button head bolts
MSRP with hoses: $470
To order, visit
Schwartz Performance - Hellcat Intercooler Manifolds
Or call (815)206-2230
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
The Following User Says Thank You to Schwartz Perf For This Useful Post:
camcojb (09-19-2018)
Old 10-22-2019, 03:39 PM
Supporting Vendor
Bump... We've got plenty in stock for your Hellcat swap!
SchwartzPerformance
GMachineChassis.com
LSxEngines.com
Old 02-05-2020, 01:16 PM
Supporting Vendor
Hey guys
We just got a fresh batch of our low-profile intercooler manifolds in!
In a few weeks we will have BLACK ANODIZED units as well.
These are a must-have for Hellcat swaps as it helps with firewall clearance... and at the same time lets you run AN hoses which is way cooler than heater hose!
-Dale
SchwartzPerformance
GMachineChassis.com
LSxEngines.com
Tags
billet, hellcat, intercooler, manifold
