Old 09-30-2018, 03:43 PM
J-440's Avatar
J-440 J-440 is offline
Default Evans radiator fluid
Anyone ever use it? Since I have an iron block and aluminum heads and radiator, I'm definitely concerned about corrosion. I'm pushing 190* all day and even in traffic so the cooling is not an issue. Thanks.
68 Charger, 440SC, EFI, 6-speed
Old 09-30-2018, 05:21 PM
I tried it once --- super expensive stuff.... and you can't contaminate it in any way.... etc.
I just returned to using DISTILLED water and a bottler or two of Redline Water Wetter - and a couple dollops of antifreeze that is made for aluminum..... never had any corrosion issues.
The Following 2 Users Say Thank You to GregWeld For This Useful Post:
Ketzer (09-30-2018), RdHuggr68 (09-30-2018)
Old 10-03-2018, 11:25 AM
J-440's Avatar
Cool. Thanks for the advice as usual brother.
