Old 10-04-2018, 08:09 PM
randy randy is offline
Default TSP Stage 2 N/A LS3 229/244, .629/.615, 112 or 111 LSA Camshaft
Any thoughts on this cam? its about time i upgrade the hotcam out of my ls3. My cam currently runs amazing but i want to add some more power and RPMs into the mix. What difference should i see with a 111 vs 112 lsa? Any reason to go with the one over the other?
Old 10-13-2018, 10:36 AM
Z06vette's Avatar
Z06vette Z06vette is offline
I use it on the 112.(i actually prefer the old specs 229/236, i like the torque retention over the 244) 111 will shift the power band down slightly, a tad rougher idle. I have used this 3 in 3 different LS3's. My current setup (229/236 112) made 448rwhp thru a tremec 6 spd, 9" w4.11s on very humid hot day. The 236/244 probably make 10-15 more peak hp.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 10-13-2018, 08:40 PM
4 hrs into it the trunnions are upgraded and the cam is about to be pulled out. Just need to pull it tomorrow and resinstall. After that upgrade the valve springs and put the rest back together. Guessing all said and done I’ll have a total of about 10 hrs into it
Old 10-13-2018, 08:49 PM
dhutton dhutton is offline
Are you going to check the PTV clearance? That’s considerably more lift than the original cam. Or does TSP guarantee no issue?
Don
Old 10-16-2018, 06:10 PM
They state there’s no issue. Install went easy. Tune in 3 weeks
Old 11-15-2018, 05:41 PM
For those wondering the difference. The hotcam dynoed higher than the location I had the tsp cam dynoed. Car rips with the new package
https://www.facebook.com/48502792/po...1688281926766/
