Old 10-14-2018, 09:33 PM
rallystyle rallystyle is offline
Default Wire recommendations
So i am starting the wiring for the battery and alternator. i am leaving the battery's in there stock locations. i see there is sgt, sgr, & sgx wire. i was thinking 2 ga for starter and 4 ga for the 150 amp alt. any recommendations on type and gauge of wire? both have ls swaps in them. Thanks
1970 El camino
1969 camaro
1996 civic
The Following User Says Thank You to rallystyle For This Useful Post:
RdHuggr68 (10-20-2018)
Old 10-18-2018, 07:33 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
GM used 2g welding cable for the ground cable in the 2008-2014 Cadillac CTS. It's printed right on it "2 gauge Prestoflex Welding cable 600v"
Old 10-20-2018, 01:44 AM
65 Drop Top 65 Drop Top is offline
Be sure to use fine strand cable
Old 10-25-2018, 08:32 AM
Andrew_at_Painless's Avatar
Andrew_at_Painless Andrew_at_Painless is offline
4 gauge charge wire will likely be overkill.
We offer a 140-190 amp charge wire setup that utilizes a 6 gauge charge wire and included the Midi fuse and everything you need: https://www.painlessperformance.com/wc/30700
We also offer a few 1 gauge high quality battery cable kits: https://www.painlessperformance.com/wc/p.php?s=caac
1998 Volvo V70 - I can't get away from them.
2007 GMC Sierra Crew Cab Classic
2018 Kawasaki Z900RS - Root Beer & Orange Retro Goodness
1971 Camaro Z28 RS - "Barn Find" -LS/4L80/Strange 9" Restomod Beater
Old 10-27-2021, 05:43 PM
ADY's Avatar
ADY ADY is offline
follow on to this thread, I have my battery mounted in the trunk and curious what gauge wire is recommended running straight to the starter? Currently have 1 gauge copper and seems to struggle when starting (voltage drops to 10.2v) with a fresh Optima Yellow Top. I've cleaned up the grounds and have a 1 foot 2/0 gauge ground to the body, so assume the long positive run from the trunk may be the issue.
thanks for any help,
-Adam
1968 Camaro SS
Old 10-27-2021, 06:53 PM
joeko23 joeko23 is offline
What size wire do you have engine to frame and frame to body? These grounds should be heavy as well. For my build I bought a 5th gen Camaro cable on eBay. In stock form it runs from trunk to engine bay so it was plenty long enough. I think it was a 1/0 wire. I also have a 1/0 battery negative to body, 4 awg body to frame and 4 awg frame to engine. Also have a 4 awg frame to core support.
My Very Ambitious 69 Camaro Build
https://www.pro-touring.com/threads/...d-0-Fab-Skills
Old 10-27-2021, 10:26 PM
ADY's Avatar
ADY ADY is offline
I have 4 gauge from the body to the frame and multiple 4-6 gauge from the motor to the frame. Initially thought the ground was the issue but didn't seem to help any cleaning and ensuring good contacts and adding a couple new grounding points.
-Adam
1968 Camaro SS
Old 10-28-2021, 06:05 AM
The only other thing I can recommend is star washers on all grounds and dielectric grease.
