Old 10-17-2018, 03:33 PM
Trick-Tools.com's Avatar
Trick-Tools.com Trick-Tools.com is offline
Default Portaband Pro Available @ Trick-Tools.com
Ever need a vertical bandsaw or chop saw at the job site? The Portaband Pro, formerly known as the EZ-CUT JIG, allows you to use your Milwaukee Deep Cut Portaband as a portable chopsaw and as an upright bandsaw. The Portaband Pro easily attaches to your Milwaukee Heavy-Duty Band Saw, corded model 6232-20 and FUEL cordless model 2729. The adjustable fence allows you to cut from 30 to 90 degree angles in PVC pipe, conduit, and metal.
This NEW improved model features a gas shock to hold the saw in the up position when used as a chop saw and has a clamping slot to use an optional PTT956k Strong Hand Clamp to hold your workpiece (fender washer to hold clamp in slot not included)
Fits Milwaukee portable band saw models 6232-20, 6232-21, 2729 only.
Available on our website at:
https://www.trick-tools.com/EZ-CUT-J...ezcut-jig-9360
•Type: portable
•Motor: Milwaukee 6232, 2729 saws only
•Mitering Range: 30-90 degrees
•Weight (pounds): 20
•Dimensions (LxWxH): 11 x 12.5 x 9.75
Brycen Smith
[SIGPIC][/SIGPIC]
