Old 10-19-2018, 06:36 PM
darkostoj's Avatar
darkostoj darkostoj is offline
Default Did I put the wrong style power steering cooler on the car?
I had this cooler laying around.
Its a Rolls Royce with a Dodge Viper V10 in a 2nd gen camaro frame with a Saginaw AGR power steering box.
I plumbed it in the return line with 3/8 tubing. The high pressure line is 8AN
I tried 3 pumps and they are all super noisy and blow power steering fluid out of the vented cap.
I see a lot of the coolers use the tube and fin style and not the reservoir style. Is that what's causing the problem?
Do I need to change the pressure valve in the pump?
I'm stumped.
Thanks!
Old 10-19-2018, 08:59 PM
Musclerodz's Avatar
Sounds like your boiling the fluid. Do you have a remote reservoir on it? Hydroboost maybe?
Mike Redpath
Musclerodz & Customz
facebook page
Old 10-20-2018, 05:33 AM
darkostoj's Avatar
Standard plastic reservoir on pump, no hydroboost.
Old 10-20-2018, 09:09 AM
Musclerodz's Avatar
If your tracking the car, you will need more cooler than that, and probably more capacity to help dissipate the heat. Shouldn't need -8 line. -6 should be plenty.
Mike Redpath
facebook page
Old 10-22-2018, 07:50 AM
BMR Sales's Avatar
definitely need more cooler. That one you have really isn't doing much at all.
Old 10-22-2018, 08:57 PM
69Camaro's Avatar
69Camaro 69Camaro is offline
I recently picked up this one from Summit. Would this be big enough for weekend autocross and the occasional HPDE? I’m running hydroboost as well.
1969 Camaro
Kore3 Z06 brakes
Hydratech hydroboost
Wilwood master
Ridetech stage 2 with truturn
Forgeline GA3 18x9.5/18x12.0
BFGoodrich Rivals 275/35 & 335/30
Magnum T56
Lots of AMD sheet metal
Sprinkled with DSE parts
Ididit Steering column
GM 376/525hp crate
Moser 12 bolt, tru-trac, 3.73:1
Speedhut Guages
Vintage Air
Corbeau LG1’s
Digi-tails
Ringbrothers
Harwood cowl
Old 10-22-2018, 09:16 PM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
There are those with electric fans as well.
