Old 11-12-2018, 04:20 PM
68LQ9's Avatar
68LQ9 68LQ9 is offline
Default One of One!
When I bought the car 26 years ago, I never imagined where we would end up.
It had a fresh .30 over 327 with a mild cam, a Turbo 350, and a 10 bolt with 2.56 gears! It was my primary car through college and into my early work career. In 2000, I went to get something out of the back seat, but when I leaned the passenger seat forward and stepped inside, my foot went through the floorboard! That began the downward spiral! The further I dug, the more rust I found, so I ended up stripping the car down completely.
Originally, I was planning to build a true street drag car. I replaced the floor pans and installed a NHRA legal 8-point roll cage.
Then life intervened, and the car began a 16 year hibernation in my garage.
During the coming years, I began to get really interested in the Pro-Touring scene, and decided to go that direction with the car. For years, I didn’t have the time or money to build the car, so I spent my free time studying, researching, trolling the web, and gathering ideas. Luckily, I found the Godfather of Pro Touring, Mark Stielow, very early, and read his Pro Touring book several times. The internet, especially Lateral-G.net, was a treasure trove of information for me, and I spent the next several years looking at many different cars and all the new parts being developed for First Gen Camaros.
A friend of mine once called my car a “belly-button Camaro cuz everybody has one!” This comment resonated with me, and I became determined to create a car that was not only a mixture of modern technology and classic style, but also a car that reflected my own vision of a Bas Ass Hot Rod!
Further down the rabbit hole I went, and I rebuilt the entire car from the ground up. Every nut, bolt, wire, etc. is new. The only part of the original car that is left is the subframe, firewall, dash, and inner body structure. Every bit of the exterior sheet metal is new. Since I already had a roll cage and subframe connectors installed, the chassis was very sturdy and square. As I am sure all of you know, nothing about these cars ever goes together easily. All of the aftermarket parts that are “made for” these cars rarely fit perfectly the first time…OK…Never! Needless to say, the bodywork on this car required a ton of time and money!
I could talk all day about what it took to build this car, but let’s just jump to the highlights.
BODY:
Completely new sheet metal (doors, roof, trunk, hood, everything!)
Custom Made Solid Lower valance panel with no fog lights or holes (Couldn’t find a single car online that didn’t have lights or holes, so had this piece made out of fiberglass.)
Billet Front Grille w/ Delta HID/Halo Headlights
New door and quarter glass
Fesler Billet Door Handles, Fesler Billet Hood Hinges, Fesler Billet Fender Supports
Fesler Flush Mount Glass front and rear windshields to eliminate the factory moldings.
No Chrome anywhere on the car! Every trim piece was either wrapped or powder coated to create the subtle clean look I was after.
Custom Wrap in Satin White Pearl
Entire underside of car is coated with Raptor Liner
Entire body interior coated with Lizard Skin for sound and heat suppression
SUSPENSION and BRAKES:
SpeedTech Tubular Upper and Lower Control Arms, SpeedTech Sway Bar, SpeedTech Chicane Kit, Viking Dual Adjustable Coil Over shocks Front and Rear, Unisteer Power R&P, SpeedTech Torque Arm Rear Suspension, Wilwood Manual 1” Bore Master Cylinder and Proportioning Valve, Wilwood 6 Piston Front and 4 Piston Rear Brakes
ENGINE:
2002 Cadillac LQ9 6.0L
Stock bottom end machined and rebuilt with new rings and seals
Stock 317 Heads with Short Side bowl Work, Valve Job, TSP Dual Beehive springs, TSP Chrome Moly Push Rods, Factory Rocker Arms with TSP Trunion Bearing Upgrade.
TSP Torquer V4 Camshaft .629/.615 Lift 231/234 Dur.
FAST LSXR 92mm intake, FAST Fuel Rails, Bosch 42lb Inj, TSP 92mm Throttle Body, RotoFab Cold Air Intake System
PRC Aluminum Radiator and Shroud w/ Dual 16” Spal Electric Fans
Mighty Mouse PCV Catch Can System
Holley High Mount LS Accessory Drive Kit
Factory GM ECU with SpearTech custom 24X Wiring Harness
Odyssey Battery and Trunk Mount Kit
Borla ProXS 3” Exhaust w/ H-Pipe
425rwhp/402rwtq
TRANSMISSION:
Phoenix Transmission 4L60e, Phoenix Transmission 3200 Stall, Driveshaft Specialist Aluminum Driveshaft
REAR END:
Currie narrowed 9”, Currie 31 spline axles, Strange Housing, Eaton TruTrac Differential, 3.50 Gears
INTERIOR:
TMI Door Panels, TMI Dash Pad, TMI Headliner, TMI Center Console, TMI Trunk Dress Kit, Corbeau Seats and 4 point Harnesses, Sparco Steering Wheel, Lokar Pedals, Power Windows and Locks, RestoMod Air Haymaker A/C system, B&M QuickSilver Shifter, JL Audio Stereo, Amp, and Speakers, AutoMeter UltraLite II Guages, GT40 Billet Window Switches, Clayton Machine Works billet Door and Window handles, and a custom back seat storage area built around 68 Corvette storage compartments.
Keith
'68 Camaro
'96 Impala SS (Built 12-13-96 The last day of SS production)
68 Camaro build
The Following User Says Thank You to 68LQ9 For This Useful Post:
syborg tt (11-18-2018)
Old 11-12-2018, 04:28 PM
68LQ9's Avatar
Default More Pics!
Keith
'68 Camaro
68 Camaro build
Old 11-12-2018, 08:24 PM
68LQ9's Avatar
Default Credit Where Credit is due!
As any of you that have built a car know, having the right people to call and point you in the right direction or get you the right parts is invaluable. While I am very proud of the fact that I built the car almost completely by myself, there were certain things that I just didn’t have the skills or tools to do properly. I must give a huge thank you to the people that helped me fulfill this dream.
First and foremost, I must thank Patti, Merri, and everyone at Firewheel Classics for putting up with me over the last two years. They have helped me so much with everything from the sheet metal for the body to my seats and interior, and even the little packs of screws and random little parts nobody thinks about. I couldn’t have done it without them.
https://www.firewheelclassics.com/shop/
For the Body Work, I had the guys at North Texas Customs do all of the cutting, welding, and sheet metal work on the car. They also withstood a large dose of my OCD, and I want to thank Tyler, Randy, and all their guys for all their help.
http://www.northtxcustoms.com/
Roger and Jay at SpeedTech Performance in Utah were extremely helpful in designing and sourcing the major Pro Touring components for my build. They supplied me with all of my suspension, brakes, cooling, steering, wiring, headers, wheels, and tires. In addition, they were always available to give me advise and share their years of experience in building Bad Ass Pro Touring Rides!
http://www.speedtech-performance.com/
Phoenix Transmissions in Weatherford, TX. is the best transmission shop I have ever dealt with. This is the third tranny they have built for me, and I won’t use anyone else.
http://www.phoenixtrans.com/
While I did build the engine myself, I do have to recognize Machine Works in Greenville, TX. for doing such a great job on machining my short block and porting my heads.
https://www.facebook.com/pages/Machi...38793026168153
Texas Speed and Performance in Georgetown, TX. were extremely helpful in designing the top end of my engine to give me exactly what I was looking for.
https://www.texas-speed.com/
Car Wrap City in Carrollton, TX. did a fantastic job in helping make my car different from every other Camaro out there! It is amazing that most people don’t realize that the car is wrapped. I had it on display in front of SpeedTech’s trailer at Good Guys Texas this year, and everyone kept asking me who painted it!
https://carwrapcity.com/
Kinney’s Muffler Shop in Ft. Worth built an awesome custom exhaust for my car. I am extremely pleased with the quality, and the price!
http://www.kinneysmufflershop.com
Finally, I have to thank Fred Heckel from Fred’s Garage. He spent a great deal of time helping me get my @@$$%% door windows aligned. I know you all know what I am talking about. That had to be the most frustrating part of the whole build.
Keith
'68 Camaro
68 Camaro build
Old 11-13-2018, 06:18 AM
nicks67ca nicks67ca is offline
Very nice! How do you like the JL source unit vs a traditional head unit?
Old 11-13-2018, 07:35 AM
68LQ9's Avatar
Default JL head unit
I love it. It’s not as deep as a regular head unit, and with the AC, it was getting tight in there. It does do radio but I mostly use Bluetooth. Only thing is it doesn’t have a clock. It’s designed for boats, so it doesn’t have all of the bells and whistles of a normal unit, but it has a strong pre-amp output.
Keith
'68 Camaro
68 Camaro build
Old 11-13-2018, 09:15 AM
68LQ9's Avatar
Default JL Head Unit
The other nice thing about the JL Head unit is it automatically switches from white to black when the headlights are turned on just like the Ultra Lite II Gauges.
Keith
'68 Camaro
68 Camaro build
Old 11-13-2018, 10:06 AM
WILWAXU WILWAXU is offline
Thumbs up
Great looking car!
What's the story behind the name (1of1)?
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 11-13-2018, 10:14 AM
68LQ9's Avatar
It is Serial No 1 of a Production Run of 1!
Trying to say it is one of a kind!
Keith
'68 Camaro
68 Camaro build
WILWAXU (11-13-2018)
Old 11-13-2018, 10:47 AM
jcal87's Avatar
jcal87 jcal87 is offline
What part of DFW are you in? I am up in Mckinney. Great looking car!
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 11-13-2018, 11:04 AM
68LQ9's Avatar
I live in Carrollton
I am also Ol' Army Class of '93
Keith
'68 Camaro
68 Camaro build
Tags
1968 camaro, firewheel classics, lq9, speedtech, texas speed
