Old 11-16-2018, 08:45 AM
GodSpeed GodSpeed is offline
Default LT4 Factory fan control
I am installing a LT4 connect and cruise but also using all the factory cooling system from a ZL1. Does anyone have knowledge of how to control the fan? I know it does it through the factory ECU as its PWM fan, but I need to know where the pin out is and if the ECU has the knowledge or if it will need to be programmed to run the fan. Or is there a away around all of it.
Thank you for your time.
