Old 11-24-2018, 12:24 PM
dgroover4 dgroover4 is offline
Default broken vacuum port on ls3 intake
Can the vacuum port on ls3 intake be replaced? Mine is cracked.
Old 11-24-2018, 02:16 PM
gerno's Avatar
gerno gerno is offline
Not sure if it can be replace. If you want to repair it I would try this stuff. I used it before with great results.
http://www.plastex.net
The Following User Says Thank You to gerno For This Useful Post:
dgroover4 (11-24-2018)
Old 02-04-2019, 01:18 PM
gnx7's Avatar
gnx7 gnx7 is offline
For N/A use you could even use JB Weld... for boosted you need a new manifold. Luckily they are cheap to buy.
