Old 12-02-2018, 08:00 AM
DT69Cam DT69Cam is offline
Default McLeod hyd T/O bearing, clutch set-up
Hey guys, anyone running a McLeod hydraulic T/O bearing set-up ?? What kind of "play" in the pedal do you have ?? My pedal pretty much is close to the floor and it seems like I have a 1/2 inch of "play". Almost feels like I cant press the pedal anymore without hitting the floor and I'm still in gear. All of the air appears to be bleed out. Also the pedal is adjusted all the way up. Hmmm.
69 Camaro Convertible (LS3/TKO in the works)
